Fusion 360 not converting files
dgentry31
dgentry31
I cannot get fusion to convert my files to 3d for printing. It just has the status bar stuck on zero. I can't see any outage anywhere, so i don't know whats going on.
Replies (10)
RajkumarIlanchelian
@dgentry31 If you run it again does the job finish successfully? We are looking at something similar where for some customers the first time the job does not complete.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
dgentry31
It does not work no matter what
clkimmeymd
same problem here.  Saving as mesh is also not functioning normally, as the units remain in mm despite changing the setting to inches.
RajkumarIlanchelian
@dgentry31
1. Can you close Fusion , restart your machine and try it again?
2. If it is still reproducible, can you create a very simple design (a box) and then run the same and see if this is happening?
Autodesk Fusion
Join Fusion Insider
dgentry31
I tried that and it worked a bit better. It managed to export 2 of the 3 parts
RajkumarIlanchelian
@dgentry31 the 3rd part that keeps failing, would you be able to share that design here?
Autodesk Fusion
Join Fusion Insider
dgentry31
https://a360.co/3QAQqTo
It's three bodies, and I just hide the other two when I want to export one of them.
It doesn't seem to be a model issue, as which model exports is inconsistent.
TheCADWhisperer
@clkimmeymd
This sounds like a different problem as stl files are unitless.
TheCADWhisperer
@dgentry31
Rather than using cloud Export
what if you simply right click on the desired Body and Save as Mesh?
clkimmeymd
There are multiple users with the same exact issue.  One of the recent updates to Fusion obviously disrupted the export function.  Fiddling with work arounds does not address the underlying issue.
