Announcements
Fusion 360 Manufacturing Model to Flat problem
geoff-hill
geoff-hill
Fusion 360 Manufacturing Model to Flat problem - see the Screencast Unable to generate FLAT Model
Replies (8)
g-andresen
there´s no body could be flattened
günther
geoff-hill
Yes - I know look at the Screencast please!
g-andresen
Hi
I would do if it was available.
günther
geoff-hill
*https://autode.sk/2GBeKEz*
*Can you see this now?*
g-andresen
At "Flat" I was in the sheet metal tools and not at "Nesting" in the manufacture area.
I think you are better advised here
günther
geoff-hill
Sorry that Link does NOT Help
g-andresen
watch some of these Tutorials
günther
jhackney1972
As I mentioned in my Screencast, the model that you posted was empty.  If you want to repost it, I will be glad to look at it.  In the meantime, I create a model that is like yours, size may be different to demonstrate.  I feel your issue is probably due to the fact you have multiple manufacturing edits and they may be interfering.  Also, I would suggest you create your arranging sketch in your design environment, it makes it a lot smoother.  My Model is attached for you to look at if you desire.  If you want to edit the arrangement, right click and select Edit Manufacturing Model
John Hackney, Retired
