Announcements
Fusion 360 MAC/PC Versions out of sync ... error opening files?
pixelwave
pixelwave
I have installed Fusion 360 both on Mac and PC.
Mac shows "Fusion 360 2.0.15509 x86_64 [Rosetta 2]", Pc shows "Fusion 360 2.0.15050 x86_64".
When I try to open a file I worked on my Mac in Windows I get an error that the file can not be opened.
Is it because the versions are out of sync? How to solve? Can I force update Windows version? It does not show an update ...
RajkumarIlanchelian
@pixelwave
2.0.15509 is on a newer schema than the 2.0.15050. This means designs saved in the newer version is not backwards compatible with older Fusion versions. I know the message is not clear on this but once you update your Windows to 2.0.15509 this should all work correctly.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
pixelwave
Yes ...that is what I thought as well.
My problem is ... I can not update the Windows Version? It tells me it is up-to-date not showing any updates?
pixelwave
Ok I solved it by redownloading Fusion 360. Seems like it was stuck on an old version. Now it works!
