Announcements
Fusion 360 Issues -- Bug Report
Wanted to report two bugs I have found with Fusion 360 on Mac, in hopes that they can be fixed!
1. Intermittently while running Fusion, the home button in the top right corner next to the rotation box disappears. At the same time, the rotation box is still visible, but you can not click on it to rotate the object (the only way to rotate then is then using the orbit tool near the bottom). These problems go away after I restart Fusion. Note, I have never experienced this on Windows Fusion, only on Mac, and I have also talked to multiple other Fusion Mac users who have the same issue.
2. After I run a simulation on a design, and then re-open the model at a later date, the model always defaults back to the simulation tab, even though I believe it should be opening on the default design tab.
Thanks for taking a look. Let me know if you need more details.
Replies (0)
