Everyone, Much appreciation if someone could help with this. Pretty new to fusion, Have Googled this thing to death. Tried several solutions no go. Problem Importing Non fusion created 2d cutting SVG, Imports upside down and also needs to be flipped horizontal. After Press pull, on to manufacture and contour selection. Weird looking contour selection lines and after manually selecting all contours the process errors with below. On to the animation process tool runs back and fourth across the top in yellow horizontal lines.
Have tried Selecting Sketch, Bodies during contour selection, Flipping z and y axis, Removed constraints, lead in and out to 0. Re-importing file after saving in Inkscape as Simple SVG.
Have tried importing other files not generated by fusion with same result.
Any help is greatly appreciated.
Warning: Closed contour has 0 area.
Warning: Overlaps found in input contours have been removed.
Generation completed with 6 warning(s) in 850.7ms.
