Announcements
Fusion 360 freezing on launch
f.m.pritchard-18
f.m.pritchard-18
Community Visitor
Community Visitor
Fusion 360 was working after initial install yesterday, however began to freeze on startup. Therefore I restarted my pc and did a clean install as directed in another forum page after the restart did not work. Any other suggestions? (did also try deleting the login file which was also suggested)
Marco.Takx
Hi @f.m.pritchard-18,
Have you checked this website?
Fusion-360-has-installed-but-will-not-launch
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
f.m.pritchard-18
Community Visitor
Community Visitor
Yup, checked that website, tried the instructions, and tried several clean installs including deleting the login file as suggested on another forum. Still freezes on startup, however occasionally when left for around an hour might launch, do not have the same issues with any more demanding program so giving up for now.
