Fusion 360 freezes the internet connection
vaino_komulainen_ax
vaino_komulainen_ax
We have had problems with the internet connection for almost two months and now it seems that the Fusion 360 freezes the internet about every 10 minutes. When the internet connection goes down, Fusion 360 goes down. When you stop Fusion via Task Manager, the internet connection returns to normal almost immediately. This connection freeze also affects all other machines on the same LAN.
This seems really strange, but could this be possible?
vaino_komulainen_ax
I have found out that it is actually Fusion 360 that is freezing the internet. But, if I change the computer's internet connection to the phone's wifi where there is a different service provider, Fusion works normally. However, the internet connection provider has not found out that there is anything wrong with their connections/settings. Maybe we just need to switch to another service provider for the internet.
vaino_komulainen_ax
Update:
We changed internet service provider and mostly the connection has worked well. However, if Fusion 360 is for example open overnight and the computer is on, in the morning the internet is stuck. When you close Fusion, a few seconds pass and all websites work normally again.
