Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
fusion 360 for 32bits
25 REPLIES 25
Message 1 of 26
fprico
39076 Views, 25 Replies
I wish fusion 360 could run in windows 7 32 bits
Labels (1)
25 REPLIES 25
Message 2 of 26
jessica.t
in reply to: fprico
Hi fprico!
Thanks for the suggestion, we have had other requests for 32-bit compatibility. We will see if we can make it happen!
Jessica Thrasher
Message 3 of 26
fprico
in reply to: fprico
Thanks for answering, I know 32 bits is not one of the newest, my computer is a quadcore and I bought it 3 or 4 years ago and it was not very cheap, and at least for now I could not change the computer only to use Fusion 360 because the computer is still working well.
Fernando.
Message 4 of 26
kat.ingalls
in reply to: fprico
Kat
Fusion 360 Social & Community Manager
twitter: @adskFusion360
facebook: /fusion360
Message 5 of 26
schneik-adsk
in reply to: fprico
We understand that some customers still have 32bit OS. We debated 32bit long and hard, but decided that looking forward with new technology was the way to go. We don't have plans to create 32bit version of Fusion 360 at this time.
Kevin Schneider
Message 6 of 26
lure23
in reply to: fprico
Fernando,
you won't need to buy a completely new computer. But you would need to buy a 64-bit license of Windows, and either a) replace your existing installment b) run multiple boots (clumsy) or c) do virtualization.
Kind of bad, I know.
Also, 64-bit Windows is not nearly as "compatible" in home use as 32-bit is (at least this used to be the case).
I understand Autodesk's stand on this, especially now that Fusion 360 / Sim 360 are in the development pipeline. Supporting three platforms instead of two would slow everything else. Maybe later on, they'll open to more platforms.
If you really, really want to run Fusion 360, check this: http://www.petri.co.il/virtual_run_a_64_bit_guest_operating_system_in_vmware.htm
Asko Kauppi
IT guy into Cleantech.
Message 7 of 26
in reply to: fprico
Message 8 of 26
in reply to: fprico
32 bits please I am student!!!
Please!!
Message 9 of 26
in reply to: fprico
I am student of autodesk. Sir i need fusion 360 in 32bit & 2gb ram because we not have more than 2gb ram.
Please Sir...
Message 10 of 26
in reply to: fprico
Anche io ho bisogno di Fusion 360 32 bit! Please! Sono passati anni e non avete ancora provveduto!!!
Message 11 of 26
James.Youmatz
Hi @Anonymous,
In questo momento, credo che non ci siano piani per rilasciare Fusion per l'architettura a 32 bit. Attualmente, non c'è modo che architettonicamente Fusion possa gestire 32 bit. Mi scuso per questo, ma a partire da questo momento, Fusion è supportato solo su architettura a 64 bit.
At this time, I believe that there are no plans to release Fusion for 32 bit architecture. Currently, there is no way that architecturally that Fusion can handle 32 bit. I do apologize for this, but as of this moment in time, Fusion is only supported on 64 bit architecture.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 12 of 26
in reply to: James.Youmatz
Peccato. Non tutti possiamo comprare PC aggiornati, ma abbiamo bisogno di studiare e utilizzare alcuni SW...
Comunque grazie per la risposta.
Message 13 of 26
in reply to: jessica.t
please make a fusion 360 32 bit, my mom worked for at least two years without spending a dime on cloths or products for her, she got me a windows 7 32 bit and i just saved up enough for a anet a8 that was on sale please please please make a 32 bit version of fusion 360
Message 14 of 26
When will u update 32Bit fusion 360 configuration, how long we are waiting........................
Message 15 of 26
in reply to: schneik-adsk
**** I have a 32 bits too and I want fusion 360 because Sketchup is  a **** !!!! **** You ****ing autodesk team !:
Message 16 of 26
Starving students must have the most current computer and 64 bit capacity.  More important than food.
Message 17 of 26
Be nice and maybe Santa will bring it next trip.
Message 18 of 26
Please get Fusion 360 available for 32 bit
Message 19 of 26
HughesTooling
If you have a PC that can only use a 32 bit operating system it will not have enough performance to run Fusion. Even on a low end 64 bit PCs it does not work well, I don't see Autodesk supporting Fusion 32 bit now. You could get a Windows 10 64bit OS and install, if your PC is not up to running Win 10 it will not be up to running Fusion anyway.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 20 of 26
TheCADWhisperer
If you read the information found in this thread you will find that the decision was made nearly 6 years ago.
