Fusion 360 - Folder lever project not listed in Data Panel
dmarquinaBFHHX
dmarquinaBFHHX
As the title says, after I log in, none of my folder-level projects show on my Data Panel, but they appear on the webadmin page.
I've already tried reinstalling Fusion 360 but nothing works.
jhackney1972
This sounds like you have not selected you correct Team Account.  In Fusion 360 go the top Project using the House icon, then at the very top of the Data Plane, select your Team drop down and make sure you are on the same one you are using on the web database.
John Hackney, Retired
dmarquinaBFHHX
Sorry I didn't make it clear, but I already am in the right Team Hub, but none of the folder level projects show.
I log in with another account that has acces to those projects, I made sure I was on the right Team Hub, and, again, only open or closed projects show.
However, in the webadmin I can access them as usually.
Could it be related to some network or firewall issue?
dmarquinaBFHHX
In the end, this issue was solved automatically, I ignore whether my campus' IT department made some changes or it was something else.
