Fusion Support
Fusion 360 file won't open syncing issues
4 REPLIES 4
drewthompson5BE9G
152 Views, 4 Replies
My project file won't open, It says there are syncing issues but as far as I can tell the file is synced and the software is the latest version,
Help please
Tags (1)
4 REPLIES 4
Hi @drewthompson5BE9G
Sorry to see that you're facing this problem.
Can you please check from
? Help > About
Screenshot 2022-12-23 at 2.51.57 PM.pngScreenshot 2022-12-23 at 2.51.50 PM.png
and confirm if you are on the latest version.
If you are on the latest version.
Then please follow below steps.
  • Close Fusion 360
  • Browse below folder
  • Take backup of<Unique Oxygen ID>
  • Delete <Unique Oxygen ID>
    • Having trouble deleting files? restart your machine and delete.
  • Restart fusion and try to open the file again
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Thank you this has sorted the problem.
Merry Christmas (if you celebrate) but all the best asnyway
Drew
Good to know problem sorted.
Yes, i do celebrate.. Merry Christmas 🎅  @drewthompson5BE9G
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
same here, last night it worked fine. Workaround works!
