fusion 360 error components are rigidly assembled
hafiz.ahmedL65YV
Observer Observer
hafiz.ahmedL65YV
Observer
Observer
Hello everyone,
This morning I was trying to join 2 parts of a vise, Jaw and base, and I keep getting this error " Components are rigidly assembled ".  I have used the Joint icon many time but today I get this problem.  Has anyone run across this problem or know a solution?  (Just did the update this week)
jeff_strater
Most likely, if this is a new design, you are seeing the result of a new capability added to Fusion recently:  Ground to Parent .  If your designs show small "anchor" badges on components:
Then, this is likely the cause of the message you are seeing.  You will need to remove this condition, using the Unground From Parent command:
Also, I would strongly recommend turning off this behavior by default, in your preferences:
Jeff Strater
Engineering Director
