Fusion Support
Fusion 360/Electronics 3D model joints constantly need redoing with unrelated changes
0 REPLIES 0
Message 1 of 1
warren_hawkins57R37
41 Views, 0 Replies
As the title says joints and 3D PCBs have lots of issues. Changing something on the board can break the joints in an assembly that uses the board. Something should be done so that the joints can be relied upon. There should be constant references generated. Adding or removing holes or other parts should not break other mates.
We've also had two glitches that resulted in empty PCBs in 3D. We had to break the link and regenerate. This of course breaks the Mechanical assemblies in fusion which can take a significant amount of time to repair. This should be fixed. I should be able to completely regenerate a 3D PCB and not break anything in the mechanical model.
0 REPLIES 0
