Fusion 360 don't lauch
daoud_jessica
daoud_jessica
Hello, I have a problem with fusion 360 which does not launch, I launch fusion 360 I connect to the browser, it redirects me to fusion 360 and after it closes and the browser puts me you have been disconnected on the desktop , I reinstalled, repaired, deactivated anti-virus, firewall and checked the prerequisites but it didn't work
Replies (8)
RajkumarIlanchelian
@daoud_jessica @Is this the first time you are connecting to Fusion? If it is can you login to login.autodesk360.com and it should ask you to accept a url in an email we send you. This should address the issue you are seeing.
if you continue to have this issue please direct message me the email ID you have registered the account with.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
daoud_jessica
Hello, thank you very much, i create new account because i don"t have a new link and i activate it work thank you
cadgraphics_expert
I see this problem, after passing some months, or you can say I have left to use it and after a few months when I tried to sign in, it doesn't direct to browse but stuck.
Then I used utility and try every option but everything was useless.
At the end, I unistalled it and download latest fusion360client.exe file and reinstalled it but the issue didn't resolve and it shows me the same problem... it doesn't open borwser after click on sign in.
Please help to resolve this issue.
RajkumarIlanchelian
@cadgraphics_expert
1. Are you on windows or Mac?
2. Have you tried using another browser as default browser and does that help?
Autodesk Fusion
Join Fusion Insider
cadgraphics_expert
I am using Microsoft Windows and I have used 2 different browsers, one is Mozilla Firefox and second is Opera.... but unfortunately, there is no luck yet.
RajkumarIlanchelian
@cadgraphics_expert To start with can you go into regkey and delete this debugger if it is there?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AdskIdentityManager.exe\Debugger
Autodesk Fusion
Join Fusion Insider
cadgraphics_expert
Thanks, I will update you soon.
cadgraphics_expert
Thank you very much Rajkumar Ilanchelian!
Your instructions were helpful at the end... It works.
