Fusion 360 does not start
igor.kudriashof
igor.kudriashof
One day Fusion 360 did not start - no errors, just blank screen with no progress. I have tried different options in the Fusion Service Utility ( repair, reset and uninstall) - the problem was not solved. The diagnosis test revelead that there is something wrong, but the domains are manually accessible. I have disabled antivirus , checked Ports and Domains requirements and other troubleshooting pages, followed the instructions, but it had no effect. I have also updated gpu driver ( and tested with the previous driver and win 10 update too). I have another laptop with the same antivirus software, test diagnostics result is the same, but Fusion 360 works perfectly. How can I fix this issue?
RajkumarIlanchelian
@igor.kudriashof Can you please follow the solution on this thread?
https://forums.autodesk.com/t5/fusion-360-support/fusion-will-not-load-on-my-desktop/m-p/11733797/hi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
igor.kudriashof
Thank You, the problem is solved!
