Announcements
Fusion 360 does not start
ferdinand.burkhardt
ferdinand.burkhardt
Hello everybody,
since some days Fusion 360 won't start anymore, it ran perfectly before. When I click the launcher a short loading symbol on the mouse appears and nothing else, no error message, no task in the task manager, nothing. I tried to uninstall it, but I got an error message saying there is a problem with the installation of Fusion 360 without any further information. I then downloaded a new installer from the website, which I could install without any problems. But still, I neither can't start nor uninstall Fusion 360.
Has anybody an idea what the cause of this is and how to fix it?
Thanks in advance
Ferdinand
g-andresen
did you use CLEAN UNINSTALL?
günther
ferdinand.burkhardt
Hello Günther,
thank you so much, it did work!
For everybody with the same problem, you can download the cleaner here: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
conjured2018
I have been using fine for a couple years, yet today fusion will not start. I have downloaded stream. exe but this gives window stating newest version is already on machine and would I like to start it. but no launch.
clean uninstall: will this remove all data, files, designs? JR
conjured2018
ok, dummy just figured out designs on cloud. did clean uninstall and now starting OK. JR
d
g-andresen
That sounds good.
Please mark posts that have led to a solution with a check mark as "Accepted Solution".
That will make it easier for future readers.
günther
