Fusion 360 does not start anymore
guillaume.lescoute
guillaume.lescoute
Community Visitor
Community Visitor
Hello for a week I have not been able to start fusion 360. I wanted to uninstall it but it is not possible, I have an error message which is displayed at each test
Here is the event log:
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\glescout\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002A9ED9C5208> #
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\glescout\AppData\Local\Autodesk\webdeploy\meta\streamer\20210709102900\resources\buildinfo.json
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20210709102900
2021-10-22 15:39:09,785 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: fr_FR
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\glescout\AppData\Local\Autodesk\webdeploy\meta\streamer\20210709102900\resources
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\glescout\AppData\Local\Autodesk\webdeploy\meta\streamer\20210709102900\certs.pem
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=True, connection=None, force_full=False, globalinstall=False, headless=False, infofile=None, install_origin='Streamer', language='en', launch_args='', logfile=None, loglevel=20, no_auto_launch=False, no_cleanup=False, no_uninstall_registry=False, operation=<function multiple_operate at 0x000002A9EE17BA68>, pipes=None, procfac=<function uninstall_process at 0x000002A9EE400168>, profile=False, pull_dest=None, purge=False, quietmode=True, stream='production', threadscount=5, update_connection=None)
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2021-10-22 15:39:09,791 - MainProcess(7520) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2021-10-22 15:39:09,791 - MainProcess(7520) - MainThread - adsk.dls.streamer.process.process - INFO :: Start to run process: Cleanup
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.registry - INFO :: Close registry connection.
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer uninstall in process"
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002A9ED9C5208> #
2021-10-22 15:39:09,822 - MainProcess(7520) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
Someone have solutions ????
عند تشغيل فيجون 360 لا يعمل وتظهر نفس النتيجة اريد الحل شكرا
