Announcements
Fusion 360 Crashes when editing (likely due to assembly contexts/linked components)
CaptainBobSim
CaptainBobSim
Hello!
I am working on a project with linked assembly contexts and derived features.
Recently everything stopped being able to edit - doing something as simple as putting a circle on a sketch crashes fusion 360 without a crash reporting window.
I reverted the model to earlier versions to see if it was a recent mistake, but the same problem happened (even in very early models).
Here is the public link:
https://a360.co/3vXObOf
I no longer need the assembly context - and would like to remove it (as I think this could be something causing the issue) but removing it crashes to desktop.
Is there any way to delete this externally, or to stop it from crashing?
dsouzasujay
Hi @CaptainBobSim,
Sorry to see that you're facing this problem.
Thanks for reporting this, I'll pass it on to the development team to investigate.
Created internal ticket FUS-98152
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
dsouzasujay
Hi @CaptainBobSim,
Our development team was able to fix the file.
Here is the fixed file:  https://a360.co/3GqsgEf
The problem was related to Parameters, with same expressions dbToolDia = dbToolDia
We have made a fix by changing the parameter dbToolDia = 0.25
We were not able to reproduce this bug with a new file.
We still need to understand on how you ended up in such (dbToolDia = dbToolDia expression) situation.
It will be good if we can get some info from you on this.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
CaptainBobSim
Thank you so much for your incredible help!
I used the Dogbone tool, to make millable corners: https://github.com/DVE2000/Dogbone
I'm not sure how this would have happened. Perhaps a mistake on my end? I set this to .125" initially.
