Announcements
Fusion 360 Crashes but Doesn't...
info99H4D
info99H4D
Hi all,
Hoping someone can help me out here.
In Fusion if I have a model open sometimes the workspace will freeze but Fusion itself doesn't.  I can't move, zoom or otherwise manipulate the object but I can still save the file and use other commands such as editing a feature.  If I switch to a different tab the browser on the left hand side updates but the model doesn't change from the one that's frozen.  When this happens I have to save the model (so at least I don't lose any work), close all open tabs and restart fusion.
This is happening once a day for me now and is quite frustrating.  The last few times it's done it I have noticed it's after the PC has gone into standby and upon reopening it's frozen in this way.  Most times however the PC can go into standby and re-open without issue.  This has happened on multiple models.
Does anyone have a suggestion?
mohammed.aliTDPXK
Hello @info99H4D ,
Sorry for the issue you are facing, could you please collect the log files when this happens and attach here?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
info99H4D
That's it done it again this morning.  Please see a copy of the log files attached.
Sam
mohammed.aliTDPXK
Hello @info99H4D ,
Thanks for the log files, I did not find any specific issue other than your network issue, are you having any trouble with the internet at your end?
Apart from this I would recommend to do a clean uninstall
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Let me know if this helps.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
info99H4D
The network issue is because the PC had recently been in sleep mode whilst I was running the program on the machine.  I came back to edit some of the tool paths and Fusion takes a minute or two to realise that it's connected to the network.
I'll try an uninstall / reinstall later today.
Sam
