Fusion Support
Fusion 360 Crashes And Won't Restart
2 REPLIES 2
mlitzkow
147 Views, 2 Replies
I have a Windows 11 system with I9-1300K and Nvidia 3060ti graphics. Left Fusion running with a couple of projects open while I was a way for several hours. When I came back there was a screen asking me to push the button to send an error report, which I did. Fusion then exited, so I tried a restart. Fusion came up, but when I tried to open my project it said something about the file was saved with a newer version and try a restart after the update finished (how would know when that is?). So I waited a while, then tried a restart. This time the splash screen hangs and nothing is happening, so I eventually kill the Fusion process with Task Manager. Now I try rebooting Windows. After that when I try to start Fusion, I don't even get the splash screen. I just get a small white rectangle, and nothing happens.  I use Fusion with a free "maker" license. What can I try?
2 REPLIES 2
jhackney1972
in reply to: mlitzkow
Probably time to check out the Fusion 360 Service Utility.  You could try the Repair option but then move up to the Uninstall if that does not work.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
mlitzkow
Yes, a reinstall did work. I wonder if there is some way to back up my preference settings just in case I need to reinstall again sometime?
