Announcements
Fusion 360 crashed when using Arrange in Additive Manufacturing
m.scopp32
m.scopp32
I just started using the manufacturing mode in fusion, so it might just be a misunderstanding on my side.
However, when I create a simple cube and try to automatically arrange it in additive manufacturing, fusion 360 keeps crashing, no matter the setup.
I can use "Place parts on platform" without "Arrange", but not with.
I am trying to slice for the Flashforge Adventurer 3 Series, which I created based upon the already existing printer in the Library Flashforge Creator Pro
Build 2.0.10564
Windows 10 (22000)
nicole.debowski
Hey m.scopp32,
Could you please give us more information? Here's what would help us out:
  • Could you please share either the design's .f3d file or the new .machine file?
  • Does the other arrange functionality work (when creating a setup or inside the collision detection command)?
  • When using "Place on platform", did you select a component or did you leave the selection empty?
  • Did you use a manufacturing model when creating the setup?
  • Was a CER report created, if so do you happen to save the report number?
Thank you in advance,
Nicole
