Fusion 360 COMBINE does not cut the 2nd letter and in a name as it works for a the first letter in the name for example MAUDE. It works with MA but not with AU and following. No new body created
pier2com
pier2com
Fusion 360 : COMBINE does not cut the 2nd letter and the following and in a name as it works for a the first letter in the name for example MAUDE (I want to do an illuminated lamp) . It works with MA but not with AU and following. No new body is created except for the 1st letter. Thank you.
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
pier2com
Hi ! I thank you very much, you helped me to resolve my problem.
