Announcements
fusion 360 cam tool window are empty white screen on mac
hi, when trying to cam procces. cam tool window is appear a empty blank white screen. im try yo uninstal and reinstall fusion but problem not solved. im adding some screenshot to attachment. do you have any ideas for solve ? thank you...
Hi. Did you ever get a resolution for this issue? I am having the same problem...
Hi,  yes i find 2 solution for this issue. First solution removing the second graphic card.  i have two graphic cards installed on my macpro system ati and nvidia Quatro  When i remove nvidia quadro graphic card problem is solved and Toolpath work normaly.
second solution ,this solution is worked even installed 2 graphic cards. go to f360 preferences panel and find the
'' preview features '' tab and then find feature called  '' tool tibrary ''  under the manufacture title and uncheck tool library box. so white screen problem solved 2 different way in my case.
i hope this solution is work for you...Screen Shot 2020-08-01 at 00.05.59.png
Hi there
Thanks for the solution, that has worked for me too :]
I'm using a black magic eGPU, so looks like it's a problem with particular graphics cards. Anyway, unchecking the 'Tool Library' box worked for me.
Cheers
Matt
