Fusion 360 Browser Sign In Not Working
theorginalprattay
Message 1 of 23
theorginalprattay
I Know This is A Rather Big Problem.
I Have Recently Downloaded Fusion 360 With a Personal License,
But I'm Facing a Rather Big Problem:
I Tried to Login Using Browser (It's Stupid), It Won't Open the Browser Window.
This Is My First Post about The Same Issue On This New Account.
Please Help Me.
Please @RajkumarIlanchelian .
I Need Your Help.
Prattay Sarkar
Replies (22)
Message 2 of 23
RajkumarIlanchelian
@theorginalprattay @Did you have a student license before and this is a new account ?
Fusion online is not for personal license.
However, I may be understanding the actual problem wrongly. Did you install Fusion 360 and on the sign in button and it is not opening a browser? If this is the case likely you just need to give permissions to the browser. Also, choose another browser as a default and see if that is working.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 23
theorginalprattay
No, I Am Using The Desktop Client For The Non-Commercial Version.
You Are Right About My Problem.
Prattay Sarkar
Message 4 of 23
RajkumarIlanchelian
@theorginalprattay @What is your default browser? When you click on sign in , can you go to your browser and see if if there is a pop that is being blocked? Also if you change your default browser to another one does that work?  Like I said this is likely a permission that needs to be given for the browser.
Autodesk Fusion
Join Fusion Insider
Message 5 of 23
theorginalprattay
I think I found the problem.
I Was Scrolling Through The Logs (Yes I debug), And I Found That In The Last Line, I Was Trying To Launch adsklicensingmanager.exe at a path, but that path was an empty Folder.
Microsoft Edge
Prattay Sarkar
Message 6 of 23
theorginalprattay
It
Prattay Sarkar
Message 7 of 23
theorginalprattay
What to do now?
Prattay Sarkar
Message 8 of 23
RajkumarIlanchelian
@theorginalprattay @Have you tried changing the default browser as I had suggested a few posts before ?
There are a couple of other things to try but want to know about the browser.
Autodesk Fusion
Join Fusion Insider
Message 9 of 23
theorginalprattay
Yah
Prattay Sarkar
Message 10 of 23
theorginalprattay
Have you seen the problem I had found?
Prattay Sarkar
Message 11 of 23
RajkumarIlanchelian
@theorginalprattay OK. If other browser is also not working, then here are two things to start with and see what the results are before we can go any further. I did see the post about you reading the logs.
1. Do you have other Autodesk products on your machine?
2. Can you right click on your launcher and "Run as an admin" and see if that makes a difference?
3. We have seen this kind of behavior with Webview2? If you go into your add/remove programs and remove the current WEbView2 and see if you can reinstall the latest one - https://developer.microsoft.com/en-us/microsoft-edge/webview2/#download-section?
Does any of the above solution help? If they do not then after you have tried these pelase do the following:
1. Go to add/remove programs
2. Select Fusion 360 - Modify
3. This will launch the Fusion service utility
4. Run the "reset Fusion 360"
5. Now launch Fusion and click on sign in- it likely will not work
6. Now go back to the service utility
7. Run gather system info
8. This will generate two zip files.
Can you attach the diagnostics logs.zip file in here, please?
Autodesk Fusion
Join Fusion Insider
Message 12 of 23
theorginalprattay
1. I Had AutoCAD 2024, But it had the same problem.
2. Sadly, No.
3. The Runtime? I Can't Uninstall It. Repaired it Tho.
Whenever I Run "Gather System Info", It Crashes WIth No Zips Made.
Prattay Sarkar
Message 13 of 23
RajkumarIlanchelian
@theorginalprattay Thanks for he extra information.
Can you confirm if you have uninstalled AutoCAD 2024? If not can you uninstall it? Now use Fusion and see if it makes a difference?
Autodesk Fusion
Join Fusion Insider
Message 14 of 23
theorginalprattay
Yes, its uninstalled
Prattay Sarkar
Message 15 of 23
theorginalprattay
Prattay Sarkar
Message 16 of 23
RajkumarIlanchelian
@theorginalprattay Which time zone are you in? We can have someone in our team connect with you on a screen share and see what Ould be happening and get this working for you.
Autodesk Fusion
Join Fusion Insider
Message 17 of 23
theorginalprattay
Ok, I Am In India, West Bengal, Kolkata With Timezone GMT +5:30 (IST)
Prattay Sarkar
Message 18 of 23
theorginalprattay
@RajkumarIlanchelian Respond Pls Il Be Free Tomorrow
Prattay Sarkar
Message 19 of 23
RajkumarIlanchelian
@theorginalprattay Thank you. We do have support from Asia that I can ask our team to look into. Will have the team contact you about details on a screen share.
Autodesk Fusion
Join Fusion Insider
Message 20 of 23
dsouzasujay
Hi @theorginalprattay
Send me an email to sujay.dsouza@autodesk.com to initiate a discussion.
Sujay
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
