Fusion 360 browser sign in failure
matejsazama
Message 1 of 12
matejsazama
I have a problem with logging into Fusion:
When I start the program it takes me to the web sign in prompt, but when I click on "sign-in" the browser doesn't open and the Identity manager reports a crash.
I've tried restarting Fusion and my PC, repairing/reinstalling fusion, changing my default browser to edge, and updating the AdSSO component.
The problem remained unchanged through all of this and I don't know what else to do.
Any help is appreciated.
Thank you very much.
Replies (11)
Message 2 of 12
RajkumarIlanchelian
@matejsazama Can you confirm if you have any other Autodesk products on your machine? There are a couple of other thing we can check on but would like to know if there are other products installed.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
RajkumarIlanchelian
Can you also please send us your log files?
1. launch Fusion and while it is launching click on Ctrl+Shift (Window) CMD+Shift (Mac)
2. This will launch the Fusion service utility
3. Gather log files
Please attach the zip file that is generated.
Autodesk Fusion
Join Fusion Insider
Message 4 of 12
matejsazama
The log files are attached.
Also: I don't have any other Autodesk product on my machine.
One more thing: When the Identity Manager crashes, it reports this error: Access violation - code c0000005 (first/second chance not available)
Message 5 of 12
matejsazama
Update: I finally caved and factory reset my PC. Afterwards everything worked fine. I don't know if there was some errors in the registry or settings, but hey, it's fixed.
Message 6 of 12
nick_cooper99
Community Visitor
Community Visitor
When this happens to me I just reinstall Autodesk identity manager and it usually solves the problem. Sometimes it is required to uninstall existing instance version first. This problem crops up far too often tho.
Message 7 of 12
chiduc80
Observer
Observer
new install fusion 360, but can't sign-in
Message 8 of 12
RajkumarIlanchelian
@chiduc80 What other Autodesk products do you have on your machine?
Autodesk Fusion
Join Fusion Insider
Message 9 of 12
mshuler1
Community Visitor
Community Visitor
I am having this same issue.   I Load the software    it directs me to the browser to sign in.  After signing in im directed back to the software and i get a sign in failure message
Message 10 of 12
RajkumarIlanchelian
@mshuler1 @Can you please send me a direct message with the email used to register Fusion?
Autodesk Fusion
Join Fusion Insider
Message 11 of 12
amir_m912
Community Visitor
Community Visitor
I am having this same issue.   I Load the software, press sign in it doesnt forwards me to browser.
i re installed and still same issue
Message 12 of 12
RajkumarIlanchelian
@amir_m912 Please follow this article https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Sign-in-in-Fusion-...
Especially try the
Backup and remove Debugger Blocked subkeys on Windows
Note: The following should be performed by an IT administrator as improperly removing folders/files or editing the Windows registry can cause computer operating system issues.
  1. Open the Registry Editor in Windows.
  2. Search [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options].
  3. Backup all the Debugger -> Blocked subkeys.
  4. Then remove all the Debugger ->Blocked subkeys.
  5. Once done, it is possible to Sign In and Fusion could start correctly.
Autodesk Fusion
Join Fusion Insider
