Announcements
Fusion 360 and FeatureCAM
Hi All, What is the easiest way to transfer a solid to FeatureCam after its drawn up in fusion 360? I thought I was told you can copy and paste but I can't find that option.
Scott
pawel.potyrala
Autodesk Support
Autodesk Support
Hi @Anonymous,
thanks for posting! To import a Fusion 360 design into FeatureCAM:
  1. Open the design in Fusion 360
  2. Go to File -> Export...
  3. Select STEP as the export format
  4. Save the file onto your local drive
  5. Import the STEP in FeatureCAM.
Let me know if that helps. Thanks!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Thanks Powel that's what I thought. I have one more question. I have 91 holes on a 6 in disk. How would I select all the holes after sketched to extrude thru?
