Fusin 360 Center of mass
jiriDVKHM
jiriDVKHM
Hi everyone. Is it possible to transfer the sign of center of mass to the 2d drawing in fusion?
jhackney1972
Take a look at this Blog Article and Video for the process.  I am not sure if the article warns you or not but the method outlined WILL NOT update automatically if the geometry of the solid model changes.  You must realign the Point to the COG every time the solid model changes.
The Blog Article and Video that defines the method of placing a point on the COG can be found here, if heeded.
John Hackney, Retired
jiriDVKHM
I'm very appreciate for your answer. But I need to transfer COG  from my 3d drawing and put it into 2d drawing (not sketch), smth like this.Screenshot 2021-10-21 095329.jpg
jhackney1972
You did not read the Blog completely as it goes through the process of doing what you asked. I cannot make the center of mass symbol, but I can place it in the 2D drawing.  Attach your model, and I will do the drawing for you.  To attach your model, open it, go to the File menu, Select Export and save to your hard drive.  Use the Attachment section to add it to your reply post.
