Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fully Constrained Lines change Position when changing parameter value
7 REPLIES 7
Message 1 of 8
produktionsmanagement
389 Views, 7 Replies
We have the following problem:
For every parametic design it's important that fully constrained objects stay on the side where you have placed them. Especially for the new configurations.
In my example i have 4 fully constrained construction lines (the line type doesn't matter). When i change the distance to the circle from 0.1 to 0.7 in picture 3 the positions are broken. The change from 0.1 to 0.6 in picture 2 doesn't do anything bad.
In picture 4 i change the distance with my mouse and position of the 4 lines was broken in a new way.
For us it's a big problem and makes Fusion360 right now kinda unusable.
Labels (1)
7 REPLIES 7
Message 2 of 8
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 8
Here is the file for playing around with the bug.
Message 4 of 8
@produktionsmanagement Sorry for the inconvenience caused & Thank you for sharing the files . We could reproduce the issue at our end with file provided by you , our team will analyse it further more.
As a work
around for now  you can change dimension to 0.6 and later 0.7.
We have logged an issue FUS-149328 for it & we are looking for the solution .
"If you find my answer solved your question, please select the Accept Solution icon"
Sameer Babar.
Autodesk Fusion 360 Team
Message 5 of 8
Hello Sameer,
I could put in a very high value like 999mm for the first configuration and then only becoming smaller, but that’s unreliable and not practical in a daily application. Also there is no guarantee that with certain downsizing steps the positions won’t get mixed up.
But I will try it, until the problem is really solved.
Message 6 of 8
So i managed to get a solution that seems working so far.
When the position of problematic lines is fixed relativ to Zero-Point and only the relevant lines change their position it seems stable.
Message 7 of 8
@sameer_babarNJS6C  and @g-andresen the problem is still existing with splines. I will upload a new file to show a situation where no workaround is possible so far...
Message 8 of 8
So here is the file:
Everytime you connect to spline like that and change the position of the spline with the parameter d4, the problem comes up.
It's super annoying, because i really need the splines...
