Hi guys, I hope this is not something silly I'm doing. I'm attempting to draw a grid of construction lines over a projected shape. The horizontal lines went down alright, snapping to the projected geometry and are fully constrained.
In another component (where the projected geometry comes from) there is a larger grid. The width of a cell is taken as a fraction of a pair of driven dimensions and stored in a user parameter, 'ModuleGridX' and 'ModuleGridY'.
Ideally, I would be able to specify 'ModuleGridX' as the spacing for the rectangular pattern on the smaller, problematic grid, but for reasons I don't understand, F360 won't allow me to use that parameter... it is just highlighted in red.
Now, because I can't use this parameter, I've instead added a driven dimension within this sketch which comes from the same dimension externally (the 939.3mm horizontal width in screencast). The rectangular pattern then allows me to select that driven dimension as the source for the spacing between the vertical lines.
When I repeat this same tactic on the horizontal lines, the existing, apparently fully constrained geometry of the vertical lines all move to the left, and all of the pattern repetitions show as underconstrained. Attempting to drag any of these points or lines around does not budge them, and I get this same result even before I dimension the line if I just draw the line first, then drag one of the points. The moment the point moves, all the vertical lines move again.
EDIT: Added project file. Can't add screencast for some reason... I get "Invalid HTML in the message body" error, even though I'm picking it from 'My Screencasts'??
EDIT 2: Link to screencast as suggested:
