Fusion Support
Front view is on the wrong plane
1 REPLY 1
jdusterh
72 Views, 1 Reply
I am having an issue with my views and planes in fusion.  Not sure how it happened but somehow my front view has the planes messed up.  My Z and X axis are on the bottom and my Y axis is going up.  Has anyone ever seen this before and possibly know how to fix it?  I have attached a photo in case my description is confusing.
Thanks.
1 REPLY 1
jhackney1972
in reply to: jdusterh
You need to go to your Fusion Preferences, by right clicking on your Avatar in the upper right corner of the Fusion desktop, and make sure your Default Modeling Orientation is set to Z-Up.  If you want your current model reoriented, please attach it.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
