@KJB5150 Can you please provide some more details?
1. Is it freezing on launch?
2. In any particular workflow?
3. Can you share your OS version?
4. Also does it crash and are you able to send in a crash report? If so can you share a report ID?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
It seems to be when I try to create a setup in manufacture. I am making a turning program and the last thing it does before freezing is give the message about calculating spun profile. There is no crash report since it freezes and sits there. I don't know if it ever would work itself out, but I let it try for 15 minutes.
I did get my turning program made, but I had to remove all of the flat faces from my model as Fusion seemed to be stuck on creating a spun profile to work from. It's the first time I've seen that particular issue and I've been using Fusion since 2016. It's possible it was something with that particular drawing. The drawing was supplied by a customer using Solidworks.
@KJB5150 Is this problem now resolved for you or do you need us to investigate ?
Autodesk Fusion
Join Fusion Insider
As of now I'm going to consider it a fluke. I'm sure if it is a bug in the release there will be more instances with other users and it can be investigated then.
