Freeze while dimension constraining
joeX8245
Message 1 of 8
joeX8245
So we have tested multiple computers and had the same freeze condition happen while trying to dimension constrain two lines in a sketch. After I click the location for the dimension, fusion freezes everytime. this seems like a simple process. I tried clearing the cache data, but no luck there. Any other ideas?
Replies (7)
Message 2 of 8
g-andresen
This is expected behaviour.
The patterns should be created in the body/surface mode instead of the sketch environment.
Create a sketch with 1 or 2 elements > extrude/cut them > pattern the features*/bodies/faces
günther
Message 3 of 8
joeX8245
I should be given a warning by the software if I'm exceeding it's feature capabilities. "Too Many ___!" Crashing isn't a helpful way to operate.
I will try patterning faces instead of sketch geometry.
That seems logically backwards though.
Message 4 of 8
g-andresen
Important:
Compute option > Identical or Optimized
but "Faces" works too
günther
Screencast
Message 5 of 8
joeX8245
I tried patterning the faces - froze again.
Message 6 of 8
g-andresen
here´s my test "Faces vs. Features"
Conditions:
1000 instances > Realtime
1. Faces
2. Features
Watch the timeline!
günther
Message 7 of 8
joeX8245
Thanks for the comparison. Are you running a 4GHz GPU?
I will try restructuring my extrusions to isolate my feature for duplication.
Message 8 of 8
g-andresen
CPU I 7  3,6 GHZ
günther
