Form, Fit and Function
mflum7
mflum7
I have a project that contains 2 seperate designs: Part A and Part B. Each are in different fusion files. I would like to bring them together into one fusion project to check for form, fit and function and maybe make changes. How is this done?
jeff_strater
Create another Fusion design, and save it in the same Project as A and B.  Insert both Part A and Part B into the new design.  Then, use the Joint command to connect them, either rigidly (using a Rigid joint), or dynamically (using one of the other, motion-type Joints).  If you want to share your designs here, we can provide a more detailed answer.
Jeff Strater
Engineering Director
