form body seems to be inexistent in manufacture tab
contiuvlad
Message 1 of 8
contiuvlad
hello. i made some extrusions in Solid tab, after that i made some extrusion followed by fill the hole in Form tab, after i finished and tried to manufacture the model i'm having a problem in manufacture tab form bodies seems to be inexistent, they are shown are not hidden. if i activate Capture Design History some of the form bodies appear in manufacture tab, some aren't. please help
https://a360.co/2GR3kx3
Replies (7)
Message 2 of 8
jeff_strater
the link you shared was not marked to allow download.  Are the Form bodies in question closed, solid bodies?
Jeff Strater
Engineering Director
Message 3 of 8
contiuvlad
now i marked the design to be downloaded
Message 4 of 8
jeff_strater
thanks.  I now have the model.  There are a LOT of bodies here.  Can you indicate which bodies are not available in the manufacture workspace?  Is it that they are not there in the "Models" folder in the browser, or they are not recognized in CAM toolpath operations?
From a quick check, it seems that all of the Form bodies are there in the Models folder in the manufacture workspace.
Jeff Strater
Message 5 of 8
jeff_strater
I checked with the CAM team, and Form bodies are not recognized by the toolpath commands.  So, if that is your problem, then you will have to convert the Form bodies to surface or solid bodies to have them recognized in toolpaths.  In a parametric design, this conversion is done automatically, which is why it seems to work differently in that type of design.
Jeff Strater
Message 6 of 8
contiuvlad
is i let the model as it is all the bodies are unrecognized in the
manufacture tab, if i enable capture design history i attached a screenshot
for you to see wich body is hidden(body 318 for example )
Message 7 of 8
jeff_strater
Your screenshot did not seem to attach.  When I open this model, and switch to Manufacture, I can see body318 in the browser, and in the scene as well:
turning off the rest of the bodies, it seems like body318 is OK:
Jeff Strater
Message 8 of 8
contiuvlad
i imported the sketch, that's why the conversion to solid from form body hasn't made automatically ?
