Font style problems OTF TTF Windows 11
ejtronics101
Observer Observer
ejtronics101
Observer
Observer
I'm trying to use a font style that I had used previously on my old PC (Windows 10) after installing Fusion 360 onto a new computer (Windows 11). When I install the TTF version of the file, I cannot select it in the list of fonts but it will let me edit text and re-render old files that used it. When I install the OTF version I can select it, but it wont render in 3d. I had a work around on Windows 10 where I could install both TTF and OTF, but Windows 11 only lets me have one at a time (presumably due to both having the same name, even with different file extensions). Can someone look into why Fusion does not show installed TTF fonts in the list?
g-andresen
Can the font be extruded?
günther
ejtronics101
Observer
Observer
Nope, there is an error saying "cannot complete extrusion", but only while the OTF version is installed. If I reinstall the TTF version, restart the application, then attempt to use the text tool (or edit existing text) I can no longer select the font from the list, but it will extrude the text(in the case where it was previously typed out in that font).
g-andresen
hi,
1. what font are we talking about?
2. try converting (explode) the font to paths
3. share the file with exploded text
File > export > save as f3d on local drive  > attach it to the next post
günther
