Font not working
Font not working
Font not working
I am using a Mac and installed a Lord of the Rings font (the in-universe characters), which are in TTF format. For some reason I can't get the text to show up in the 3D file in the proper characters, they just keep sticking to Roman Characters in Ariel. How do I get the Tengwar characters back, the computer is set to treat them as the
roman alphabet.
Try This:
In the text command at the bottom of the application window,  type the following command:
Sketch.TextWritingSystem /any
I solved this type of problem with help from this post - https://forums.autodesk.com/t5/fusion-360-design-validate/ttf-font-not-showing-up/m-p/7992278/highli...
Hope it helps
Hi.  It seems I'm having the same issue.  I tried your text command but I get an error that Sketch is not defined.  I changed the term 'Sketch' to the name of my sketch ('Sketch5') but I've still got nothing.
My issue is the same aside from the fact that I'm trying to change from the Arial font to another font that comes with Fusion 360.  It appears that the font is just not applying to my letters.
