Announcements
FOLLOW-UP FROM 2020 - Hidden lines appear when zooming out (in design mode)
sutherland-
sutherland-
Dear community,
I would like to follow up on the thread that I found here.
It is quite annoying that some of the non-visible object lines (hidden to the camera, e.g. behind other objects) are reappearing when zoomed out and disappearing when zoomed in. If I move the object that is behind the visible object further away, then the issue is fixed, but this is not how things work, especially when distances matter and if a quick screenshot is needed.
Is there really no way of fixing this? Or have no-one looked into this since 13-12-2020?
Example can be seen here:
Best,
@sutherland-
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
sutherland-
Up.
Best regards,
Level  sutherland-
Member
sutherland-
Up.
Would like to at least get an answer.
Best regards,
Level  sutherland-
Member
