fly outs have a problem since last update eg web flyout. they just flash on and
830403205
830403205
fly out just flash on and off, should stay while pointer is over em,
ui tabbed is a complete mess not logical or complete
James.Youmatz
Autodesk Support
Autodesk Support
Hi @830403205,
Sorry to hear that! Can you try the solution documented in this article here? In the screencast, if you undock the toolbar, dock it to the bottom of the screen, and then dock it back at the top - this should resolve the problem.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
mroek
@James.Youmatz
As soon as a tool is used (or Fusion is restarted), the problem reappears, so that is not a really a workaround if you're actually going to do some work in Fusion. That said, this error doesn't prevent working, it's just a bit annoying. And slightly embarrasing that it has been reintroduced in this new update.
team must just fix it ,that's all, simple as that, not good for newcomers. or image of software
