Message 1 of 10
Flat pattern
How can i make this to a flat pattern?
Is it Sheet Matal part?
Needs to have edges perpendicular to faces.
Might help....
It`s a body and i cant convert it to sheetmetal.
Yep, looks like it was made with Loft.
If not converting, will be the non square edge (right side of pic) or not constant thickness, holding you back.
Might help....
you need a flat face
günther
@jonas.holmstedt wrote:Hi,
1. for conversion into sheet metal part, the thickness of the component must be constant. This is not the case here.
2. in addition, there must be a flat surface for unfolding, which can be added additively perpendicular to a flat edge.
günther
Why do you have Capture Design History turned off?
Turn history back on
remodel the part from scratch with history and then re-attach the new attempt here.
