Announcements
Flat pattern in drawing, not working from an assembly
mac_ito
Message 1 of 10
mac_ito
Why is it not possible to display a flat pattern of a component present in an assembly when it is possible from a single component?
Replies (9)
Message 2 of 10
ClintBrown3D
Hi @mac_ito
I'll ask the team to take a look into this for you, in the meantime, please try the workflow below:
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 3 of 10
mac_ito
Hi, could the problem come from the fact that my assembly is not a sheet metal component, as in your example
Message 4 of 10
sutherland-
Hi @mac_ito
It would be always recommended that you create sheet metal component if you are working with sheet metal, since then it is easier to adjust the specific sheet metal parameters when working with the file.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 5 of 10
mac_ito
yep I imagine but how to do
Message 6 of 10
sutherland-
If the body allows to then you could use this feature:
Best regards,
Level  sutherland-
Member
Message 7 of 10
mac_ito
Yep but does not work for an assembly
Message 8 of 10
mac_ito
Indeed it works
Message 9 of 10
mac_ito
how do you get that?
Message 10 of 10
sutherland-
You can re-create this by creating an external sheet metal body, then when you open it, you can make more sheet metal bodies within that sheet metal. Images attached.
There might be an easier way to do this though.
Best regards,
Level  sutherland-
Member
