Fusion Support
Flat Pattern for Box and Pan Brake
2 REPLIES 2
erwinbiermans
68 Views, 2 Replies
Hello, I have been using Fusion 360 for a while and love it. I used the sheet Metal part before, and I noticed that the Flat Pattern I create does not give me correct bend lines. I think it's because the Flat pattern created is if you have a Press Brake. I only have a Box and Pan Brake. Is there an option to adjust Fusion 360 for the Tool I have? I am open for any suggestions you have.
2 REPLIES 2
You probably need to adjust your K-Factor value in your applicable sheet metal rule for you Box and Pan Brake.  I would recommend a free application called BendsWorks that will help you determine the correct K-Factor for you machine.  You will find the application here.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
@erwinbiermans
Can you Attach a file here that is not correct and explain what about the geometry is not correct?
