Flat Pattern error
I can't create a Flat Pattern on this sheet metal in the picture (which I can't upload for some reason below here, thus I attached it). Though I am curious why it doesn't work, I realized it has to do with the last flange command I performed. When I go back to the previous state, it does create a Flat Pattern. What is the reason it gives an error? Unfold command still works without problem. So, if Unfold works why not Flat Pattern? Below you can also find the file. I would appreciate any explanation.
