Hi!
I've stuck with this. I try to make outline to cut oracal sticker which in turn goes onto profiled sheet metal.
My workflow:
1. Make target sheet metal profile in Sheet metal workspace. I use custom Rule with .1 mm thickness.
2. Get sticker outline sketch with such an angle to metal sheet that I want it to be read correctly. In this case 45 degrees.
3. Extrude -- Cut this sketch through metal sheet
4. Then I make flat pattern (goes ok) and when I try to export DXF I've got this 'unexpected problem'
One else guy reports the same issue with this workflow. Other sheet metal models do not generate this error.
I've examined metal sheet edge after extrude and found this artefacts:
So obviously this workflow has a flaw but I cannot understand how to overcome it.
Any ideas?
Now we have workaround without DXF export involved.
My model with download permission - http://a360.co/2CLdpZ2
Pavel Medvedev
Курс по Fusion 360 на русском
Youtube on Fusion 360 in Russian - DadaPasha
Facebook | VK | Fusion 360 Telegram chat
