Fusion Support
Flat Pattern DXF Export Broken Geometry
2 REPLIES 2
mikeHGCK7
165 Views, 2 Replies
I have had a reoccurring problem within the sheet metal workflow in fusion where my exported DXF's contain broken geometry.
In the past I have found the error was often caused by modifying the bent material with an extrusion or otherwise. This time however, I am running into issues that I can't find the source of. My exported DXF contains broken geometry no matter how I export it. I have made sure that edges are square and nothing intersects the bend area.
I could get around this problem if I were able to export a regular sketch with a bend line, but as far as I know that is not possible.
I attached a couple of images to show the problem.
2 REPLIES 2
jhackney1972
in reply to: mikeHGCK7
Please attach your Fusion 360 model and not an STEP file.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
mikeHGCK7
in reply to: jhackney1972
Hi John,
I'd rather not share the assembly file publicly. I can however send it to you.
Is there a way I can email or pm you the file?
