Hi! Thank you for the information. I've been working on trying to model a spiral sheet that can be flattened / unfold. Your example looked to work exactly like I need but I have trouble trying to repeat the process. I tried to go step by step according to your file, but I just cannot somehow replicate everything. For example, there is the step of extrude, and i see it has created just a thin extrude of the spiral. but even if I just try to edit the feature and deselect the profiles, and choosing the profile again, it makes a completely different feature with double walls, attached screenshot.
Then I tried to overcome this by using surface-delete-face, to remove the additional faces to make it look similar as the sample. and next trouble comes when I try to make the contour-flange, it just doesn't seem to work like in yours, and even when I combine then what I get there, it never allows to unfold the design.
I couldn't find any tutorials online for this, could you please provide a bit more details how to do this, it is amazing that Fusion 360 has this possibility and just a pity that I cannot find out how to do it!
