Newby, unsure whether I'm posting to the correct board...
If you select the elements of the sketch that will not be further modified, fix them, and then create the additional elements that interface with the previously mentioned elements, does trimming actually result in a risk of any elements moving or not being machined/cut/whatever correctly? (See Screen Shot attached.)
IOW, I fix the [steering wheel] spoke sides immediately after sketching them, I fix the outer rim immediately, then draw the inner rim, and finally the spoke-to-inner rim transition circles.
When I trim away the unwanted lines/arcs, I get the warning regarding lost dimensions/constraints.
What am I missing here? Thanks in advance for your thoughts.
