Announcements
FILLETING PROBLEM
BrianPES
FILLETING PROBLEM
BrianPES
CAN SOMEBODY PLEASE TELL ME WHY I CAN NOT FILLET THE INTERSECTION BETWEEN THE STRAIGHT LINES AND THE ELLIPSE, IN THE ATTACHED FULLY DEFINED SKETCH.
jeff_strater
Sketch Fillet does not support trimmed ellipses today.  Instead, can you apply the fillet in the solid model instead?
Jeff Strater
Engineering Director
jhackney1972
The reason is that an ellipse is a very complex entity so the Fillet command, in sketch mode, cannot calculate the radius.  It is better to add the Fillets in Solid mode anyway, do it there.
John Hackney, Retired
jeff_strater
another approach, if you decide there is some compelling reason to want to do this in a sketch (I would not do that) is to just add the arc yourself.  You can set tangent constraints to the line and the ellipse, and specify a radius.  You don't need to do the trim (in fact, there is really no reason to trim the ellipse in the first place), because you can just select the needed profiles for any feature.
Jeff Strater
BrianPES
Many thanks Brian
