Fillet Not Working
Fillet Not Working
Fillet Not Working
Why can't I give a fillet on top of this structure? are there any technical constraints that I have to look into? How can I give at least a 4mm radius fillet on the marked edge?
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @Anonymous, thanks for posting.
I think the fillet will be limited by the angle of the sides of your model. It is probably not physically possible for such rounding to be done in this case. I tried to more or less recreate your model and the maximum fillet I could get without an error was 7mm. If possible reduce the angle between the top surface and the side wall and see what rounding is possible.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
TrippyLighting
That is almost impossible to answer without having access to your model. Export as .f3d and attach to your next post.
TheCADWhisperer
@Anonymous
Works fine for me in my test.
