Announcements
Filess created on Mac wont open on Windows version
ronanJ9MBL
ronanJ9MBL
I am having an issue where files created on my Mac version of Fusion 360 will not in my Windoes version.  They are both on the same version of 2.0.17954 x86_64.  I get the following error in Windoows when i try to open a file:
"Unable to open
Fusion 360 is unable to open FILE_NAME. It may not have been synced correctly. Make sure evrything is saved, restart Fusion 360 and try again."
Does anyone know what coould be causing this issue?
Thanks!
RajkumarIlanchelian
@ronanJ9MBL Can you please do the below?
1. Close Fusion on windows
2. Delete the short cut that you use to launch Fusion
3. Go to add/remove programs
4. Select Autodesk Fusion - MODIFY
This will launch the Fusion service utility.
5. Run the Repair Fusion
This will now repair and also create a new short cut for you.
Now try to open the design and let us know if that helped.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ronanJ9MBL
Amazing... that sorted out the issue.
Thanks!
RajkumarIlanchelian
@ronanJ9MBL Glad this worked!
Autodesk Fusion
Join Fusion Insider
