Feature request: path-parametric Pattern on Path
The Pattern on Path feature is very powerful, but so far I have found in all of my use cases that I really want to give dimension information in path-parametric terms. That is, I want to specify numbers in the range 0.0 and 1.0, not in millimeters, much as one does for Plane Along Path. (0.0 is one end of the path, 1.0 is the other end, and 0.5 is halfway along, however long the path might be.)
In particular, my needs generally fall into the form "Put N widgets evenly spaced along this path, with the first widget at one end and the last widget at the other end."
I can definitely see the use case for physical units (e.g., millimeters), but that seems like a more specialized case.
