Feature Request: Make Fusion 360 User Interface Responsive while Long Calculations.
One of the most unnerving things with Fusion360 is the unresponsive user interface while long recalculations. This is especially troublesome with large parametric models.
If you change a profile for example, and this causes a problem later in the timeline, it may be already too late. Fusion360 get stuck somewhere, running at 100% CPU, and you know it will not work – but there is no way to stop the process. Often I have to terminate Fusion360 if it gets stuck - sometimes I lost the last modifications I made.
Also, if the user interface is not responsive anymore, the operating system is sometimes affected. The window can not be moved freely, etc.
So my feature request:
- Make the user interface responsive while long calculations. There may not be any command available, but it should be responsive for the user and the operating system.
- Implement a Stop or Cancel button. It shall work like this: The current calculation is stopped and after confirmation, the action which caused the recalculation is reverted (undo). Alternatively, the calculation is stopped and the history-marker is placed just after the modified element - so the user can perform the operations step-by-step.
Best,
LR
